Activity › Forums › Apple Final Cut Pro Legacy › Firestore import issues
Posted by Dan Blackwood on August 3, 2011 at 12:50 pmThe video from teh FS5 looks great on interviews, but if there is any motion whatsoever, the edges are jagged up, like the fields don’t match or something. Is there a setting I can change to fix this?
Dan Blackwood
Coordinator, Video Services
West Virginia Department of EducationDan Blackwood replied 15 years, 1 month ago 3 Members · 7 Replies -
Jerry Hofmann
August 3, 2011 at 1:11 pmDid you transcode the FS5’s media to ProRes before you edited? If not try that.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Dan Blackwood
August 3, 2011 at 3:54 pmI will check both things. No, I did not use Pro Res 422, and I am not sure of the field order. Thanks.
Dan Blackwood
West Virginia Department of Education -
Jerry Hofmann
August 3, 2011 at 6:40 pmHouston, you have a problem… the AVCHD files should be prores instead. How did you import them?
Jerry
Current DVD:
Dan Blackwood
August 3, 2011 at 6:47 pmFirst, I imported them using File>Import. Then I imported by XML, using auto for the settings, then tried ProRes 422. Same result all three times.
Dan Blackwood
Jerry Hofmann
August 3, 2011 at 7:09 pmYou brought the AVCHD files in as ProRes files with the Log and Transfer tool?
Jerry
Dan Blackwood
August 3, 2011 at 7:10 pmCorrect, no difference.
Dan Blackwood
