Activity › Forums › Panasonic Cameras › FIRESTORE Frame Rate ISSUES
  • FIRESTORE Frame Rate ISSUES
    Posted by Don Wilson on May 10, 2006 at 1:31 am
    I am struggling with the workflow with my Firestore and Final Cut and hope someone on the awesome Cow can help.
    I have the camera set in 720/24p….want the cine look. Record to the Firestore. What is the best way to get the footage into FCP and not have to render. My test has been frustrating. I set the FCP (V 5.0.4.) sequence to 720/24. P2 originated footage is no problem. I used the Panasonic Frame Rate Conversion plug-in and it still wants to render the footage. Does FCP V5.1 fix this? Am I being a moron like my ex-wife(s) says? I’ve been editing most of my adult life but this one has me so far. As well, the Firestore has the option to record DV Raw in DVCProHD, what is that? I can find no info in the documentation.
    Many thanks!
    Don Wilson
    AmericanaMediaInc.com
    Barry Green replied 20 years, 4 months ago 4 Members · 4 Replies
  • Gary Adcock
    May 10, 2006 at 2:35 pm
    [Don Wilson] ” Record to the Firestore. What is the best way to get the footage into FCP and not have to render. My test has been frustrating. I set the FCP (V 5.0.4.) sequence to 720/24. P2 originated footage is no problem. I used the Panasonic Frame Rate Conversion plug-in and it still wants to render the footage. “
    Don
    check your sequence settings again. It sounds as if there is a mismatch somewhere. Make sure that you are set to DVCPROHD 720p24 and not something else.
    Run the 720p24 easy set up THEN create a new Seq and the footage should be seen correctly
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Chicago, IL
    gary@studio37.com
  • Noah Kadner
    May 10, 2006 at 5:37 pm
    Make sure in camera you are set to 24pA.
    Noah
  • Don Wilson
    May 10, 2006 at 7:11 pm
    Noah,
    I haven’t had the camera set in 24pA. Can you explain why it would matter to change to the 24pAdvanced setting. I am trying to learn everything I can about this process. How would the Advanced setting affect the Firestore recording? I’m sure it is some simple thing like that you guys will enlighten me on and all this head-scratching will be over.
    Many thanks,
    Don Wilson
  • Barry Green
    May 10, 2006 at 8:17 pm
    Ignore the 24pA thing — that’s for 1080, and you’re working in 720. If you’re using 1080/24 with FCP, you want to be using 24pA, but for 720 there isn’t an option for 24pA.
    Perhaps Noah meant “use 720/24P, not 720/24PN”?
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
