Activity › Forums › Apple Final Cut Pro Legacy › Firestore drives to compress seq real time
Posted by Pedro Casais on June 16, 2009 at 2:47 amI’m thinking about using this kind of drives or similar to compress my sequence, any experience with this thought?
best,
Michael Sacci replied 17 years, 3 months ago 3 Members · 3 Replies -
Shane Ross
June 16, 2009 at 3:27 amCompress to what? These drives are designed for cameras…what are your plans?
Shane
Read my blog, Little Frog in High Def -
Pedro Casais
June 16, 2009 at 5:15 amWell, firestore allows you to choose the compression you want to have as you your camera feeds the video signal to it. Why can’t we do the same as we play our sequence from fcp?
best,
Michael Sacci
June 16, 2009 at 6:09 am[pedro casais] “firestore allows you to choose the compression” No they don’t, you have to set the Firestore to match you camera’s setting. So if the camera is on HDV, the FS is on HDV, if camera is DVCProHD, the FS is DVCProHD and so on. The Firestore does NOT do any compression.
