Forums Panasonic Cameras Firestore and gap in video
  • Firestore and gap in video
  • Shane Ross
    July 7, 2006 at 6:57 pm
    We have heard about this issue…when people shoot video to the Firestore and the firestore breaks it up into chunks and how those chunks, when assembled in FCP, have 1-2 frame gaps.
    Well this guy noticed that, but linked the clips in iMovie and said that in that application there were no gaps:
    https://discussions.apple.com/thread.jspa?messageID=2680137#2680137
    Can someone else verify this?
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Don Wilson
    July 7, 2006 at 9:51 pm
    It’s all about how FCP reads the flagged frames to drop in the pulldown process. How does iMovie do it and if this guys wasn’t doing 23.98 it’s moot. I know Focus is all over a solution. I’ve had it bite me badly!
    Don Wilson
    AmericanaMediaInc.com
  • Christopher Wright
    July 8, 2006 at 7:33 pm
    It looks like he was using the FS-4 and not the FS-100, so he was not doing HD or 24 fps footage. What is interesting to me is that even the DV footage on the FS-4 seems to have the same problems as the FS-100 HD 24fps clips in FCP HD. Not a good sign….
  • Dean Sensui
    July 9, 2006 at 8:16 pm
    I just got an FS-100 and when I first dropped 720p60 footage onto a sequence I noticed the black gaps.
    However, I’d inadvertently dropped it onto a standard DV-NTSC sequence.
    When I created a 720p60 sequence and dropped the same imported clips onto it, the gaps disappeared and played back seamlessly.
    Dean Sensui — http://www.HawaiiGoesFishing.com
  • Don Wilson
    July 9, 2006 at 9:53 pm
    Dean,
    What do you mean “Dropped” into a sequence. Do you have some method of linking these seperated files together? I have to make individual edits and know of no short cut way to do this, do you?
    Don Wilson
    AmericanaMediaInc.copm
  • Dean Sensui
    July 10, 2006 at 2:11 am
    Don…
    I grabbed the clips and placed them into the appropriate sequence.
    It was a test where I ran the camera for several minutes. The Firestore created three seperate clips just over 2 minutes long. The contents of the Firestore were copied over to a RAID and imported into Final Cut Pro.
    I then selected the three clips and dropped them into the sequence timeline. They were in the proper order, butted tightly together, with no gaps.
Viewing 1 - 6 of 6 posts
Log in to reply.
