Activity › Forums › Web Design (WordPress, Joomla, etc.) › Firefox black line issues
  • Firefox black line issues
    Posted by Phillip Makselan on May 23, 2008 at 8:23 pm
    I have created a website and it works fine in IE and Safari. When I open it in Firefox (only on the pages with Flash Video) I get black lines that show up on the top right of the flash vid and on the left side under a few links and on the side. It almost seems like it is an issue with the flash video constraints. However, when I refresh a few times it goes away. It may be a problem with my code I was told. I made the site in Imageready and Dreamweaver as I am a novice and only changed background color and centered with code. The site is https://mirageproductions.com/wildwest
    Phillip
    Curtis Thompson replied 18 years, 4 months ago 2 Members · 1 Reply
  • Curtis Thompson
    May 23, 2008 at 9:11 pm
    hello…
    it’s something in your table that firefox is getting hung up on – with a table of that complexity, it’s impossible for me to say w/o manually futzing with it, but something in there is not making firefox happy – it could be your tags that have wraps in them or the newlines/spaces between content and the ending td tag for that cell or a variety of other things (like the flash movie itself for reasons due to embedding)…
    i would start by removing things and see how it goes – the first thing to take out would be the flash movie itself – put in a filler image at the exact same size as the flash movie, and if the lines don’t happen after that, then you know your culprit – at that point, start messing with that embed code and see what happens – change the size of it, params, etc. until you can track it down…
    not the simple answer you were hoping for, but it’s the best i can offer…hope that helps!
    sitruc
