Activity Forums Adobe After Effects Firefly effect
  • Firefly effect
    Posted by Zebsophia on December 3, 2006 at 8:31 pm
    What is the best way to animate a solid dark background to look as if there are fireflies glowing and fading? I would need just a few frames that I could then loop. Thank you.
    Zebsophia replied 19 years, 9 months ago 2 Members · 2 Replies
  • Graham Quince
    December 4, 2006 at 2:39 pm
    Sounds to me like the best way would be to use the circle fitler and animate its position to dart around the screen. you could even use the ‘motion sketch’ tool to get a really organic look. On top of that, add the glow filter and play around with the settings a bit.
    When you’ve got one animation you’re happy with, you could always duplicate the layer and change the transfer mode to Add and move it around in space to see two sychronised fireflies. Or delete the position keyframes and do another motion sketch
    Hope that helps
    Graham
    https://www.quinceweb.com – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
  • Zebsophia
    December 4, 2006 at 3:15 pm
    I will give this a try. Thank you very much for your help.
