Activity Forums Adobe After Effects Fire plugin — burning paper?
  • Fire plugin — burning paper?
    Posted by Mark Pi on June 15, 2006 at 2:50 am
    Need a shot of a few photos (will be digital stills) catching on fire. They should look like regular pictures, and the burning should be gradual — photo turns brown in a spot which spreads, then flames catch. The angle will be from the top looking down at a slight angle.
    Even better would be something that also curls the paper and distorts the photo as well.
    Are there any plugins which do something like this? I checked out various fire and flame plugins but none seemed appropriate.
    David Bogie replied 20 years, 3 months ago 4 Members · 4 Replies
  • Mark Pi
    June 15, 2006 at 3:00 am
    Forgot to mention that I saw the “Using Fractal Noise to Create Fire” tutorial, but I’m looking for something more subtle.
    The shot lasts only 5-10 seconds, and will slowly zoom in to the photo while it begins to distort and burn — not necessary to see flames.
  • Justin Productions
    June 15, 2006 at 3:01 am
    Tutorial.
    DigiEffects Delirium = Plug-in.
    Or, COW Archives.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • Mike Clasby
    June 15, 2006 at 6:25 am
    Stylize>CC Film Burn
    And the pattern of darkening to burn spots can be controlled with the Center and Random Seed properties, then just animate the Burn from 0-100 (or less) to get you blackening.
    And if you animate Stylize>CC Glass (or CC Blobbylize), that will give you the bubbly look of print heating to the point of burning.
    Sometimes Roughen Edges (with the Edge Type>Roughen Color) works with this setup.
    Anyway Film Burn and Glass will get you toward Darkening => Bubbling => just before flaming.
    You can even get a little curling with page turn, but you need to precomp the stuff above to get the curling backside showing the blackening and Roughen Color.
  • David Bogie
    June 15, 2006 at 9:35 pm
    Back in the olden days, when CoSA took a weekend to render ten seconds of one layer, we saw this post often. Our usual response was to buy some pyrotechnic supplies from a magician supply shop, and shoot it. You can find A-B fire fluids that offer some interesting control over the course of a fire as well as colored flames, spark and flash powders. Print ten or fifteen copies of your shots and have some fun.
    bogiesan
