Activity Forums Apple Final Cut Pro Legacy finishing sequences within fcp
  • finishing sequences within fcp
    Posted by Dan Crouch on May 5, 2011 at 5:39 pm
    I have just finished cutting a movie trailer for cinema and for internet.
    There is no money for an online and colour grade so I am delivering the quicktime direct to client.
    As I can’t have an online to check the peaks etc of the luminance levels etc, is there a way in fcp that will make everything legal?
    There are a few negative images that flash up for example, and I need to make sure it doesn’t fail a tech review.
    Any advice on this would be greatly appreciated.
    Thankyou in advance.
    Dan.
    Dan Crouch replied 15 years, 4 months ago 2 Members · 2 Replies
  • Doug Beal
    May 5, 2011 at 6:17 pm
    depending on your graphics card the scopes in FCS 3 are very close. That should give you an idea of what’s goin on.
    check effects>color correction> Broadcast safe filter
    Be aware that “everything” legal would include audio levels. often overlooked
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Dan Crouch
    May 5, 2011 at 6:25 pm
    Thank you for post.
    Does that mean I simply select whole of video layer and
    apply effect and render it.
    Cheers,
    Dan
