Activity Forums Apple Motion Finishing an unfinished path
  • Finishing an unfinished path
    Posted by Tom Fox on August 4, 2015 at 1:24 pm
    Hello All,
    I have been drawing a bezier path and accidentally deselected it. I cannot seem to select the end point in order to continue drawing the path. It only wants to start a new one.
    I would have thought shift-clicking or some such would work but no such luck. Surely it must be something incredibly simple….
    Mark Spencer replied 11 years ago 2 Members · 3 Replies
  • Mark Spencer
    August 4, 2015 at 1:33 pm
    You can’t add more points after the end point of an open shape once you’ve created it. But you can add more intermediate points – option-click or double-click anywhere on the line. So you can drag your last point out of the way, then add more points before it.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Tom Fox
    August 4, 2015 at 1:46 pm
    Thanks for that Mark,
    Is there any point to that?
    I was just using the space bar hand tool (à la photoshop) and didn’t get the pen back when I had let go.
    Somewhat tedious but your workaround does work.
    Cheers,
    T
  • Mark Spencer
    August 4, 2015 at 3:04 pm
    You should definitely be able to pan the Canvas with the spacebar while drawing a shape and be able to keep adding points.
    Mark Spencer
