Activity Forums Adobe Encore DVD Finished DVD won’t play
  • Finished DVD won’t play
    Posted by Rob Sgarlata on February 7, 2006 at 1:54 pm
    I tried to search first, but I’m not very good at it so excuse me if this has been covered.
    I built a project that has one menu, one sub-menu and one audio/video file. When I run “Check Project” I get no errors, when I preview the project everything works perfectly, the main menu comes up, if I click “Play” the video runs, if I click “Scenes” I get my sub-menu and all of the links work. When I burn the dvd everything seems to go perfectly. However, the dvd will not play on any of my players. They all say “reading,” or “loading” but nothing happens. On my PC the dvd will not autorun, however, if I open my software player and manually select the drive then it will work.
    First Play is set to the main menu.
    What am I missing?
    Joe Feng replied 20 years, 7 months ago 3 Members · 8 Replies
  • 8 Replies
  • Joe Feng
    February 7, 2006 at 10:13 pm
    Could be the blank media you’re using…
  • Jeffrey
    February 8, 2006 at 12:52 pm
    I have had that problem with DVD+R’s before…try using a DVD-R if you are not already. If you are, it may be just a bad disc, try burning it again using another disc from the same spindle. I have heard it is better to burn the DVD files to a hard drive folder, then use a burning program like Nero to actually burn the files to a disc, maybe that will work. Perhaps the most obvious thing to check would be to make sure your dvd burner supports the type of DVD you are trying to burn (for example your dvd burner may only burn up to 8x and you are using 16x dvds).
  • Rob Sgarlata
    February 8, 2006 at 1:49 pm
    Thanks for the suggestions guys. Last night I uninstalled some programs that are known to cause conflicts with Encore and burned another DVD. No good. On another forum it was suggested that I try a lower data rate for encoding, but I have not run into this problem before with the same data rate. I am beginning to suspect bad disks. I did not buy them myself and they are +R. I typically use -R. It could be the speed issue, although I think my burner can do 16x.
    I’ll report on what I find.
    Thanks again.
    Rob
  • Joe Feng
    February 8, 2006 at 9:29 pm
    another thought, I’ve had some problems with buring from an internal burner on our HP workstation, and the same project burned perfectly using the same computer, only with an external burner. After speaking with HP, I upgraded the firmware for the internal drive and that seems to have solved the problem. (Knocking on wood) I think the problem had to do with the way different burners writing lead-outs differently or something of that sort…
    So, check to see if a firmware upgrade is available for your burner.
  • Rob Sgarlata
    February 8, 2006 at 9:53 pm
    I will check on that
  • Rob Sgarlata
    February 8, 2006 at 10:03 pm
    Here is an interesting point. Over the last two weeks I have burned probably 60 DVD’s of this exact type using my burner. These have been copies of a teaching that took a total of five DVD’s and I have made about a dozen sets. Today I had someone at the church run through a random sample of the disks and see if they work. He said they all worked flawlessly.
    These were copies made using Nero, no encoding or authoring done. So, to me that largely (but not completely)rules out media problems and burner problems, so right now I am thinking (hoping) it is a data rate issue. I will know later tonight.
  • Rob Sgarlata
    February 9, 2006 at 1:56 pm
    Well, I still have not found the solution so I want to try using Nero to burn the DVD. Everything seems to be working fine up to the point of actually burning the DVD. I even burned an .img file onto my harddrive and used my software player and everything worked perfectly.
    The DVD’s are burning, I can see the information on the disk, they just won’t play!
    How do I do the Nero process? Out of Encore do I choose “dvd folder?” Then when I open Nero what option do I use for making a DVD that will play on set-top players? I don’t have to use Nerovision and reencode, do I?.
    Thanks for all the help.
  • Joe Feng
    February 10, 2006 at 6:22 pm
    In Nero, I think all you have to do is choose the DVD Video Disc option and drag over all the files from the Video_ts folder written by Encore. I believe it would also work if you simply burn the Video_TS folder as a data DVD.
