Activity Forums Apple Final Cut Pro Finer control over effect parameters
  • Finer control over effect parameters
    Posted by Jason Jenkins on July 15, 2016 at 1:42 am
    I’m using Hawaiki AutoSplit and I’m trying to adjust the position of the images, so they fit together seamlessly across the screen. I can’t get them lined up because the position controls will only allow me to adjust them in tenths. I’ve always had trouble getting fine control in the inspector, but it’s finally reached the point of, “There’s gotta be a better way!”.
    If I select the number and use the up/down arrow keys, it adjusts by tenths. Using any keyboard modifiers gives the same result. If I try typing a number, out to the hundredths, it just rounds to a tenth. If I click and ‘scroll’ with my stylus, the results are erratic. This particular effect has no on-screen controls.
    What am I missing?
    Jason Jenkins
    Better Video Starts Here
    Nick Toth replied 10 years, 1 month ago 3 Members · 4 Replies
  • Jeremy Garchow
    July 15, 2016 at 3:55 pm
    I’d write Hawaiki and ask about it. Simon and team are very helpful. I’d imagine they would have to adjust parameters to get them to get you a bit more fine control. Usually holding option is what softens the range, but if it’s not working for you, the fix will need to come from the developer.
  • Nick Toth
    July 15, 2016 at 7:49 pm
    Are you using multiple sizes or all the same size?
  • Jason Jenkins
    July 15, 2016 at 9:57 pm
    [Nick Toth] “Are you using multiple sizes or all the same size?
    They are all the same size. I ended up buying the mFrame plugin from motionvfx. It’s the third, and best, split screen plugin I’ve tried so far.
    Jason Jenkins
  • Nick Toth
    July 18, 2016 at 1:12 pm
    All you have to do is apply one of the presets to each clip and set the x and y values.
    If you have three across you use the A1 preset on each clip and set the x values to 0, .5 and 1.
    For 3X2 use C1 and set the X values on each clip to 0, .5 and 1 for left, middle and right and the y values to 0 for the lower row and 1 for the upper row. etc.
    Not sure why you’re having a problem with Hawaiki. I use it all the time with no issues.
