Activity Forums Adobe After Effects fine tooth comb
  • fine tooth comb
    Posted by Norman Frizzle on May 31, 2006 at 3:30 pm
    I want the import DV into AE, after converting it to progressive scan for highly critical process effects on it at the highest bit rate for color/luma.
    Does AE ‘intelligently’ eliminate or minimize ‘combing’ in merging the two fields, or do I have no option but to deinterlece and use interpolation?
    Roland R. kahlenberg replied 20 years, 3 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    May 31, 2006 at 3:44 pm
    You need AE to deinterlace the fields if you want to prevent the dreaded combing effect for your non-interlaced output. You need to ensure that AE correctly interprets your DV footage as lower field. Interpreting fields will force AE to deinterlace the fields while setting it to lower field ordering will ensure that you are correctly interpreting the field ordering for DV footage.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
