Activity Forums Maxon Cinema 4D fine dashed line
  • fine dashed line
    Posted by Brian Williams on July 8, 2008 at 10:36 pm
    I’m just learning C4D and I’m having a problem with a render. I’ve swept a circle spline along a helix spline and applied a material with gradient transparency at both ends. When rendered I get a thin dashed white line along the entire shape. It may not be dashed, maybe ducking in and out of the object. It goes away if I turn banking off, but then I get other problems. Any one seen this?
    Brian Williams replied 18 years, 2 months ago 1 Member · 1 Reply
  • Brian Williams
    July 11, 2008 at 5:22 am
    Found it. A texture tag that was UV mapped just a pixel shy of a seam.
