fine-control in time-line
Hello folks. This is my first post and I’m a newbie to media production. I just recently bought the Sony Vegas Platinum Pro Pack and I’m feeling my way through as best I can. I have managed to produce several simple productions with multiple video clips and simple transitions in this Vegas Movie Studio 9. I made a couple others with inter-bedded stills and video using a trial copy of Corel VideoStudio. Corel was simple and very intuitive but ultimately I thought I’d outgrow it, and so chose Sony instead.
There are a number of things I’ve tried to do in Vegas but have yet to figure out how-to. Last night I came up against the following that I could not manage. I am trying to sync a video clip with terrible audio to a beautifully recorded and mixed audio clip and then of course transition the audio from the bad into the good at an appropriate point:
–splitting an individual audio clip inside the time line area without splitting the video/voice clip above it (synchronous with it). I know where the Edit/Split feature exists from the drop-downs and have used it successfully when I only had video/voice in the time line.
–volume transitions (fades, increases) in the middle of an audio or voice clip. I found the horizontal “bar” to graphically lower the volume of the entire clip but I don’t know how to put “slopes” inside a clip. Do I want to split the clip and then just end-transition the vol?
–fine control when syncing the audio/video. I’m zoomed into the time line area and I can see exactly what I need to line up for a perfect sync, but the clips drag in discrete jumps–it never lands right where I want it; always fore or aft. The audio clip is a .wav file and video is a .avi. This is the one I thought I would not find easily in the tutorials and need your help with most.
–moving whole sections of clips/transitions. On occasions, I want to grab a section of work I’ve done and slide it out of the way, thereby opening empty time. I saw the Insert/Time in the drop-down, but have not experimented with that yet. Can’t you just highlight (for example) the entire rear-end of your production and drag it out to the right?
Thank you.
