Activity › Forums › Apple Final Cut Pro Legacy › Finding Timecode
  • Ben Northenor
    March 2, 2010 at 5:54 pm
    Thank you so much! That is Brilliant advice. I really appreciate your feedback as it will help me make my decision. You guys are so awesome for helping! Thanks again!
    http://www.bennorthenor.com
  • Larry Asbell
    March 2, 2010 at 9:46 pm
    One very important additional step to add to Mike Raff’s explanation: Before you drag the batch of clips to a timeline, make sure there are no In or Out marks on the clips! To see this, set the bin to Show In and Out columns. If any of the clips show a TC number in those columns then select all clips and right click on any In TC and select “Clear.” Do the same for the Out Column. Now all clips should show “Not Set” for Ins and Outs. If you don’t do this your sequence would contain only the marked section rather that the whole of each clip.
    – Larry Asbell
  • Ben Northenor
    March 2, 2010 at 9:52 pm
    Awesome! Thanks for the heads up.
Page 3 of 3
