Activity Forums Square Box CatDV Finding the right code for using user field as a variable in Worker
  • Finding the right code for using user field as a variable in Worker
    Posted by Henrik Helms on September 27, 2012 at 6:10 pm
    Hi!
    I must say – I am NOT an expert in programming. But I have made a task in worker which will start if the status is put to “Make web proxy” then it will create a webproxy and I want it to be put in a new catalog which name is set in user field 19. Which code do I write to the catalog name field in worker?
    Kind regards Henrik
    Henrik Helms replied 13 years, 11 months ago 2 Members · 2 Replies
  • Matthew Stamos
    September 27, 2012 at 6:38 pm
    Look in Worker Read me PDF
    ${id} Value of arbitrary clip fields, eg. ${U12} is User12, ${NT} is the Notes field
  • Henrik Helms
    September 27, 2012 at 6:49 pm
    Greetings
    Henrik Helms
    dBA MEDIA
