Activity Forums Adobe Premiere Pro Finding the right audio effect
  • Finding the right audio effect
    Posted by David May on May 18, 2008 at 7:03 am
    Hi Guys, just a quick question about using the audio effects in Premiere Pro 3. Ive recorded a voice over and was wanting to use an audio effect to change the tone of his voice a bit (no “hardboiled detective” presets funnily enoigh) The actor who recorded for me had a blocked nose and some of the words are a bit slurred, but an effect or 2 should stop that from being too noticeable. I have audition, but no clue how to use it and would like to stay fairly well contained in premiere. Its a bit of an odd question, but I just wouldnt know where to start.
    Thanks all.
    Dave
    Vince Becquiot replied 18 years, 4 months ago 3 Members · 2 Replies
  • Tom Krauska
    May 18, 2008 at 12:37 pm
    Audition was taken out of Premiere CS3, so I’d first try some of the Audio Effects in Premiere.
    Audition is a very sophisticated and complicated program.
    You could also try and learn SoundBooth which is part of CS3.
  • Vince Becquiot
    May 18, 2008 at 7:15 pm
    You’ll have to work with the EQ. It will be a combination of boosting some frequencies and knocking down other, I’m afraid there is no rule of thumb here as every voice is unique. Just work in the 800 – 1K range to start and make small changes as you can make the overhall mix a lot worse as well.
    Cheers,
    Vince
