Activity › Forums › Adobe After Effects Expressions › Finding the remainder of a division sum
  • Finding the remainder of a division sum
    Posted by Jim Lefevre on March 9, 2012 at 4:31 pm
    I’m needing to get the remainder of a division sum.
    I have a slider which has the values of 1 to 365 (DAYS_YEAR) and I need to cycle something that takes 29 days to cycle (MOON_PHASE) but using that DAYS_YEAR as its driver.
    I have figured out that if I divide my DAYS_YEAR driver by the MOON_PHASE
    (DAYS_YEAR)/(MOON_PHASE)
    I get a result which all I need is the ‘remainder figure’ (the underlined figure beneath)
    e.g.
    (DAYS_YEAR) / (MOON/PHASE) (MOON_ROT)
    ……….1…………………..29…………..=………….0.0344827586206897
    ……….28………………….29…………..=………….0.9655172413793103
    ……….29………………….29…………..=………….1 (doh!)
    ……….30………………….29…………..=………….1.03448275862069
    … the remainder that I take from that I use as a percentage to drive the MOON_PHASE rotation…
    If I can get that remainder figure then it would be
    360*MOON_ROT
    to give me the degrees it goes round
    I searched through the forums and have found one of the hallowed Mr Ebbert’s posts on the %
    https://forums.creativecow.net/readpost/227/7858
    but I’m struggling to make it all work.
    I has thought that I could use the % function but I’m getting rather bold single integers
    ((thisComp.layer(“DAYS_YEAR_DRIVER”).effect(“DAYS_YEAR”)(“Value/Offset/Random Max”))%thisComp.layer(“MOON_PHASE”).effect(“MOON_PHASE”)(“Slider”))
    Where
    DAYS_YEAR_DRIVER is a layer with the date as a single integer value
    and
    MOON_PHASE = 29
    as always, many thanks in advance for taking a look!!
    http://www.jimlefevre.com
    Jim Lefevre replied 14 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 9, 2012 at 6:12 pm
    The simplest way to get a remainder is probably the JavaScript modulo operator (%). You would use it like this:
    num = 0.0344827586206897;
    remainder = num%1;
    Dan
  • Jim Lefevre
    March 14, 2012 at 8:10 am
    Thank you! Yes, I’m there! And what’s more I think I understand!!
    As always, many many thanks Dan.
