Activity Forums Adobe After Effects Expressions finding the longest text
  • finding the longest text
    Posted by Adam Greenberg on May 10, 2022 at 5:59 pm
    Hi all, if i have an if else statement in a project that controls the length of a solid based on the length of the text.
    It was easy for 2 text layers, because i assigned x to the length of a text layer with sourcerectattime, and y to the other text layer. and I am using a specific time also because of the animation of the text ( so lets say the 2 second mark )
    Now I have more layers, and also some of these layers are coming in later, lets say 7 seconds. So I am not sure how to solve this without making this more complicated.
    here is my original expression,
    gap = 36;
    L = thisComp.layer(“TEXT1”);
    M = thisComp.layer(“TEXT2”);
    rect = L.sourceRectAtTime();
    rect2 = M.sourceRectAtTime();
    x = L.toComp([rect.left+rect.width,0],2)[0];
    y = M.toComp([rect2.left+rect2.width,0],2)[0];
    xclamp=clamp(x,545.70,2000);
    yclamp=clamp(y,545.70,2000);
    if (x>y) xclamp+gap;
    else yclamp+gap
    now if I only add 1 more layer, my expression would be this
    gap = 36;
    N = thisComp.layer(“TEXT3”);
    rect3 = N.sourceRectAtTime();
    z = N.toComp([rect3.left+rect3.width,0],7)[0];
    zclamp=clamp(z,545.70,2000);
    if (x>y)&&(x>z) xclamp+gap;
    if (y>x)&&(y>z) yclamp+gap;
    else zclamp+gap
    so if i had 6 text layers, this expression would be extremely long. Is there a function I am not aware of that would allow me to bypass writing 5 if else statements each having 5 ”&&” like this for example ;
    ( this is just 1 line )
    if (x>y)&&(x>z)&&(x>z2)&&(x>z3)&&(x>z4) xclamp+gap; and so on….
    thanks for any help
    Adam Greenberg replied 4 years, 4 months ago 2 Members · 6 Replies
  • Dan Ebberts
    May 10, 2022 at 6:38 pm
    I think I’d do it with a loop. This won’t be exactly right (I haven’t tested it at all), but maybe it’ll get you headed in the right direction:
    gap = 36;
    layers = ["TEXT1","TEXT2","TEXT3"];
    times = [ 2, 2, 7 ];
    maxX = 0;
    for (i = 0; i < layers.length; i++){
    L = thisComp.layer(i);
    x = L.toComp([rect.left+rect.width,0],times[i])[0];
    maxX = Math.max(maxX,xclamp);
    maxX+gap
  • Adam Greenberg
    May 10, 2022 at 6:58 pm
    thanks so much. I will test it and come back and post with the outcome
  • Adam Greenberg
    May 10, 2022 at 7:07 pm
    Im getting an error here;
    layer index 0 out of range
  • Adam Greenberg
    May 10, 2022 at 7:44 pm
    starting with your lead and other research, how about this ?
    t1 = thisComp.layer(“TEXT 1”).toComp([thisComp.layer(“TEXT 1”).sourceRectAtTime().left+thisComp.layer(“TEXT 1”).sourceRectAtTime().width,0],2)[0];
    t2 = thisComp.layer(“TEXT 2”).toComp([thisComp.layer(“TEXT 2”).sourceRectAtTime().left+thisComp.layer(“TEXT 2”).sourceRectAtTime().width,0],2)[0];
    t3 = thisComp.layer(“TEXT 3”).toComp([thisComp.layer(“TEXT 3”).sourceRectAtTime().left+thisComp.layer(“TEXT 3”).sourceRectAtTime().width,0],2)[0];
    t4 = thisComp.layer(“TEXT 4”).toComp([thisComp.layer(“TEXT 4”).sourceRectAtTime().left+thisComp.layer(“TEXT 4”).sourceRectAtTime().width,0],2)[0];
    t5 = thisComp.layer(“TEXT 5”).toComp([thisComp.layer(“TEXT 5”).sourceRectAtTime().left+thisComp.layer(“TEXT 5”).sourceRectAtTime().width,0],2)[0];
    t6 = thisComp.layer(“TEXT 6”).toComp([thisComp.layer(“TEXT 6”).sourceRectAtTime().left+thisComp.layer(“TEXT 6”).sourceRectAtTime().width,0],2)[0];
    xclamp = clamp(Math.max(t1,t2,t3,t4,t5,t6)+20,545.70,2000);
    [xclamp,value[1]]
  • Dan Ebberts
    May 10, 2022 at 8:42 pm
    Yes, sorry–that should have been:
    L = thisComp.layer(layers[i]);
  • Adam Greenberg
    May 10, 2022 at 11:48 pm
    ok great, your idea is much more straight forward.
    thanks Dan
