Activity Forums Adobe After Effects Expressions Finding the Global Scale Value of an object?
  • Finding the Global Scale Value of an object?
    Posted by Darryl Torke on October 3, 2012 at 3:48 am
    I have a layer (result_layer) that uses the scale property of another layer for it’s value. However, that secondary layer is a child of a parent that is scaled up by a few factors. When I use my expression all I get is the child’s scale, not the true/global scale.
    What I am trying to find out is the global scale property of the child layer. Is this possible in After Effects?
    result_layer's scale expression (to which I only get the child's 'local' scale:
    thisComp.layer("CHILD").transform.scale*.5;
    Wouter Dijkstra replied 7 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Dan Ebberts
    October 3, 2012 at 6:12 am
    Something like this:
    L = thisComp.layer("CHILD");
    s = L.transform.scale;
    while (L.hasParent){
    sp = L.parent.transform.scale;
    s = [s[0]*sp[0],s[1]*sp[1]]/100;
    L = L.parent;
    s*.5;
    Dan
  • Darryl Torke
    October 4, 2012 at 4:47 am
    it worked! thank you
  • Wouter Dijkstra
    May 28, 2019 at 10:10 pm
    I’m having the same sort of issue. I have a PreComp that is 2160×3680 and I put this in a smaller comp. Now parented this Precomp to a null, but now I’m not able to see how far I scale my PreComp. Since I don’t want to go beyond the maximum resolution (scale > 100) I would like to have some kind of controller that will tell me when I reach 100.
    Of course I could check this by unparenting my PreComp from the null, but is there a way where I can check the absolute/global scale value at all times even when it is parented to another layer and therefore relative data?
  • Oleg Pirogov
    May 29, 2019 at 1:52 am
    This gives an absolute scale (in %) of parented layer:
    L=thisComp.layer("CHILD_LAYER");
    length(L.toWorld([1,0,0])-L.toWorld([0,0,0]))*100;
  • Wouter Dijkstra
    May 29, 2019 at 7:47 am
    Hi Oleg,
    For some reason it doesn’t work the expression you gave me. You apply it to the “Scale” Property and Child layer?
    This eventually turned out quite nicely. I don’t understand the code, but it works:
    s = scale[0];
    L = thisLayer;
    s = s*L.parent.scale[0]/100;
    L = L.parent;
    s
  • Wouter Dijkstra
    May 29, 2019 at 8:21 am
    I might have cheered too soon.
    It gives me an error:
    expression result must be of dimension 2, not 1
    Is this an easy fix?
  • Tomas Bumbulevičius
    May 29, 2019 at 8:51 am
    Wouter, as easy as it could be, one of the easiest in fact, hehe!
    Scales requires an array of 2 or 3 items. Just add retrieved value into array and you will be good to go.
    [s,s]
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
  • Wouter Dijkstra
    May 29, 2019 at 9:53 am
    ???? I should have known. Thanks for clearing it up –> It works now.
