Activity Forums Avid Media Composer Finding out the reel length??
  • Finding out the reel length??
    Posted by Brittany Oliphant on July 24, 2008 at 5:34 pm
    I am assistant editing with Avid and on a film that will be telecined. (is that telecine past tense?) Well I was asked to find how long each reel is. The reels are four different sequences. I was under the impression that the Avid can tell me this straight out. From my investigation I think it can be found where the timecode is on the record monitor. Under footage? Its already set as “footage-35.4-MAS” and the numbers come up as “2164+03” is that the reel length in feet and inches? If not…where can I find it?
    Brittany Oliphant replied 18 years, 1 month ago 2 Members · 4 Replies
  • Job Ter burg
    July 24, 2008 at 8:40 pm
    It’s feet and frames, not feet and inches. If you don’t know how to measure I/O in Avid, ask someone to point out the various options to perform that task.
  • Brittany Oliphant
    July 24, 2008 at 9:07 pm
    Thats the problem of this entire job. I do not have anyone to ask. The editor is gone, and the assistant editor before me bailed.
    I do know about I/O’s. I was just wondering about the reel length.
  • Job Ter burg
    July 24, 2008 at 9:11 pm
    Then Mark In and Out at the beginning and ending of each sequence, and – either above the Record monitor or in the Timecode Window (under Tools) – create a line that counts I/O, and make sure you select the right counter type (in this case, 35mm 4-perf is likely to make sense). If you are to measure in minutes and seconds, make sure that the Master TC is counting at the right speed (especially in PAL).
  • Brittany Oliphant
    July 24, 2008 at 10:09 pm
    Thank you for the help! I really appreciate it.
