Finding out format on DV Tape
Hey,
a friend gave me some DV Tapes to capture for him but unfortunately he doesn’t know what Format there where filmed on. He also doesn’t know what kind of camera it was filmed on and I’m using my own HDV cam to capture the footage. Is there any way that I can find out what the format/frame rate etc. on the tape is so that I can set up the capture settings correctly?
The aspect ratio is actually 4:3 so I figure it must be dv and not hdv footage. Also the camera was bought in Australia so I figure it should be PAL and on the footage are some artifacts what I believe are due to the footage being shot interlaced. So my best guess for the Footage is now that it is DV50i PAL. But is there any way how I can find that out for sure?
When I capture the footage in FCP with a DV PAL setup the footage appears to be slightly squished.
Also when I capture the footage I get a message telling me:
“The audio sample rate of one or more of your captured media files does not match the sample rate of your source tape. This may cause the video and audio on these media files to be out of sync. Make sure the audio sample rate of you capture preset matches the sample rate of your tape”So I guess that I would need another preset but all of the presets in FCP have a 48kHz sample rate, so the format on that tape appears to be a little odd I figure.
Any help would be appreciated 😉
Kind regards,
Neil
