Activity › Forums › Adobe After Effects › Finding missing frames in a sequence.
  • Finding missing frames in a sequence.
    Posted by Waldemar Werbel on August 30, 2009 at 10:40 pm
    Hi all.
    I was asked an interesting question by a friend earlier today. He’s importing a .tga sequence rendered in a 3D app – on import there are 2 frames missing from the sequence. Normally this isn’t a big deal as most sequences tend to be a couple of hundred frames long and a quick scrub through shows up the identifying place-holders. His sequence is thousands of frames rather than hundreds…
    Is there a script available that will scan the contents of the directory where the sequence resides and give you a heads up where the sequence breaks? Or maybe there’s an even simpler method that’s eluded me?
    So far I’ve suggested that he opens up the directory and goes into ‘list’ view and re-sizes the window to wrap the bottom of a column on a file which is a multiple of 10 – scanning along the last file of each column should reveal a missing frame pretty soon (ie where the number of the frame changes to 0049/0059/0069 etc – the missing frame will be in that first column) It’s still a bit of a faff, though – a script to do the work for you would be an excellent tool to have at your disposal, don’t you think?
    As ever, thanks for any help anyone can offer.
    w.werbel. uk.
    https://homepage.ntlworld.com/w.werbel/showreel/
    David Mackenzie replied 10 years, 7 months ago 6 Members · 6 Replies
  • Peter O’connell
    August 31, 2009 at 3:25 am
    Hi, using a scripting language would do the trick for this kind of thing. The python code below, for example, makes a list of all the files in the given directory and sees if the padded number of each subsequent file is 1 more that the previous (given a padding of 4, eg.”078_080_comp_v09.0001.tga”). I can’t post this code to the cow as text because of the way the cow handles white spaces, unfortunately, but here is a screen grab. Hope this helps.
    Rogue Keyframe
    Feature Film Compositing
  • Jeremy Fabiano
    August 31, 2009 at 6:11 am
    the above script would do the trick for missing files.
    This solution would find ones that were created, but not rendered to (null/empty files).. (although the python script could VERY easily be modified to handle this at the same time and be a lot faster – unfortunately I can’t help there, been too long 🙁 )
    go into “details view” in your file browsing system (wether youre on windows or mac, they both have their equivalents – sry im not a mac guy anymore dont remember what its called).
    and then arrange by size lowest to highest
    the crappy frames that were incorectly rendered or are blank will be at the top (if they did get rendered – usually the file DOES get created, but nothings in it so it’ll have a really small filesize).
    Best I can do, hope it helps out!
    -Jeremy
  • Waldemar Werbel
    August 31, 2009 at 9:36 am
    Thanks guys – both excellent suggestions! Looking forward to trying that script.
    Cheers.
    w.werbel. uk.
  • Markus Mustermann
    April 2, 2011 at 1:18 pm
    a friend of mine wrote me a batch script for windows that identifies missing files (frames) in sequence and prints the frame numbers in a txt file.
    it’s ideal for long sequences – however it only checks if the files exist – so broken files will not be reported.
    here ist the script: (copy paste in text document and rename missing.BAT)
    this script checkes the folder: c:\folder0\”folder number one”\
    for missing files named: FileName[#####].png
    @echo off
    set startframe=3383
    set endframe=6425
    set leading=0000
    set folder=c:\folder0\”folder number one”\
    set filename=FileName
    set ZAEHLER=%startframe%
    set neuerChunk=0
    :start
    if “%ZAEHLER%”==”%startframe%” echo MISSING %filetype% FILES in %folder% – start:%startframe% end:%endframe% list:>> missing_frames.txt
    if “%ZAEHLER%”==”%endframe%” goto end
    set z=%leading%%ZAEHLER%
    set z=%z:~-5%
    if not exist %folder%%filename%%z%%filetype% (
    if “%neuerChunk%”==”1” (
    echo ##### >> missing_frames.txt
    set neuerChunk=0
    echo %z% >> missing_frames.txt
    ) ELSE (
    set neuerChunk=1
    set /a ZAEHLER = %ZAEHLER% + 1
    goto start
    :end
    echo end of list >> missing_frames.txt
    echo check missing_frames.txt
  • Frederick Ross
    June 5, 2013 at 7:58 pm
  • David Mackenzie
    February 10, 2016 at 1:47 am
    A very easy way is Davinci Resolve. In the Source Media screen, simply drag the folder containing the broken image sequence down into the Media Pool.
    An intact sequence will appear as one item. But if there are breaks detected, Resolve will create several clips in the pool, and the names will let you find where the breaks are.
