Activity Forums VEGAS Pro Finding it difficult to create a simple project.
  • Finding it difficult to create a simple project.
    Posted by Julian Milano on January 28, 2013 at 12:03 am
    I’m new to Vegas.
    I’ve imported all my raw video onto my PC and here is a sample of the media Information:
    General
    Complete name : D:\Media\Video\[2012-09-15] Josh & Joey's Wedding\Source\Julian's HDR-XR260VE\2012-09-15\20120915090208.MTS
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 161 MiB
    Duration : 51s 108ms
    Overall bit rate mode : Variable
    Overall bit rate : 26.4 Mbps
    Maximum Overall bit rate : 28.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=1, N=12
    Codec ID : 27
    Duration : 50s 400ms
    Bit rate mode : Variable
    Bit rate : 24.9 Mbps
    Maximum bit rate : 26.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 50.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.240
    Stream size : 149 MiB (93%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Format settings, Endianness : Big
    Codec ID : 129
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 2.69 MiB (2%)
    Text
    Menu ID : 1 (0x1)
    Format : PGS
    Codec ID : 144
    Duration : 49s 855ms
    All I want to do is edit out a few scenes and put in a few transition between scenes but it’s just too difficult. Here are my issues:
    1. Based on the Media Information from the source video, how should I render the output so that there is no re-encoding? Is this possible?
    2. Most of the render formats I choose give me the error “An error has occurred while opening a codec.”. I installed the K-Lite Mega Codec Pack V6.6.0 which seems to cover some of the codecs. Is there a codec pack which has ALL the codecs for Vegas?
    3. I rendered using Sony AVC/MVC – “AVCHD 1920×1080-50i 5.1 Surround” but it just seems that the quality is poor.
    Am I doing something wrong or is there another software package I should be using instead to get the best quality with 5.1 surround sound?
    +– JDMils
    +– Sony Vegas V11
    +– Sony HDR-XR260VE
    John Rofrano replied 13 years, 7 months ago 2 Members · 1 Reply
  • John Rofrano
    January 28, 2013 at 12:00 pm
    [Julian Milano] “1. Based on the Media Information from the source video, how should I render the output so that there is no re-encoding? Is this possible?”
    No this is not possible in Vegas Pro. You will need to render using Sony AVC and one of the “AVCHD …” or “Blu-ray …” templates.
    [Julian Milano] “2. Most of the render formats I choose give me the error “An error has occurred while opening a codec.”. I installed the K-Lite Mega Codec Pack V6.6.0 which seems to cover some of the codecs. Is there a codec pack which has ALL the codecs for Vegas?”
    You should never install any codec paks. The fact that you have already done so means that you may never get this to work properly. Uninstalling them doesn’t always work. What you have done is replaced the high quality codecs that you purchased when you bought Vegas Pro, with free substitutes which don’t always work (as you have seen) basically throwing your money away.
    I would uninstall all codec paks and re-install Vegas Pro and hope that this fixes your problem.
    [Julian Milano] “3. I rendered using Sony AVC/MVC – “AVCHD 1920×1080-50i 5.1 Surround” but it just seems that the quality is poor.”
    This could be due to your installation of codec paks. The “real” Sony AVCHD encoding is very high quality.
    [Julian Milano] “Am I doing something wrong or is there another software package I should be using instead to get the best quality with 5.1 surround sound?”
    You went wrong when you install a codec paks on your computer. Don’t do this because it will always mess up Vegas Pro.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
