Activity › Forums › Adobe After Effects › Finding “Ease In/Out” Key
  • Finding “Ease In/Out” Key
    Posted by Tim Scarpino on June 7, 2007 at 1:56 am
    Greetings all,
    I use AE 7 at work on a PC and use the F9 key once I highlight keyframes to “turn on” the Ease In/Out function. Works like a charm.
    Problem is, I’m using AE 6.5 at home on a G4 running OS X Tiger and I when I hilight my keyframes and press F9 (per AE Help), I don’t get the Ease In/Out keyframes, rather, the whole desktop wants to do some funky OS X thing where all the windows move around. I am using an EX keyboard bought with FCP
    Any thoughts?
    Thanks in advance!
    Tim Scarpino
    Eric Jones replied 19 years, 3 months ago 2 Members · 1 Reply
  • Eric Jones
    June 7, 2007 at 2:27 am
    F9 is used as an Dashboard & Expose hot key as a basic default in MacOS X, hence the “funky” screen behavior of everything shrinking. Go to your System Preferences and select “Dashboard & Expose”, you can then change the hot keys or turn them off completely, freeing them up for After Effects.
    Hope this helps,
    Eric Jones
