finding duplicates
Posted by Doyal Gudgel on September 29, 2012 at 3:36 pmI want to know the easiest way to find duplicate pictures in a project media window . I am sure Vegas has this figured out but it escapes me. I have the same pictures appearing in the project twice or more but don’t know an easy way of finding them.
thanks.Doyal Gudgel replied 13 years, 11 months ago 5 Members · 12 Replies -
John Rofrano
September 29, 2012 at 4:06 pm[doyal gudgel] “I want to know the easiest way to find duplicate pictures in a project media window . I am sure Vegas has this figured out but it escapes me.”
No it does not but you can purchase the an extension called Audit Assistant that will find events with duplicate media for you very easily.
It does require Movie Studio Platinum 12, Vegas Pro 12.0, or Vegas Pro 11.0 in order to work.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Aleksey Tarasov
September 29, 2012 at 6:26 pmAnother tool that can help you is Project Auditor from Vegasaur toolkit
Doyal Gudgel
September 29, 2012 at 8:16 pmThanks. Really surprises me though that Vegas doesn’t have it built in. I’ll do it the old fashioned way seeing the amount of use I need it for. This one shot. I do appreciate the info.
John Rofrano
September 29, 2012 at 10:03 pm[Aleksey Tarasov] “Another tool that can help you is Project Auditor from Vegasaur toolkit”
Does Vegasaur toolkit support Movie Studio? I don’t think it does. The VASST FasstApps support Movie Studio 12 as well as Vegas Pro 8.0 thru 12.0. Doyal uses Movie Studio which is why I recommended the Audit Assistant FasstApp.
~jr
Aleksey Tarasov
September 30, 2012 at 8:59 am> Doyal uses Movie Studio
But he said Vegas…
> “Does Vegasaur toolkit support Movie Studio?”
No, it doesn’t (at least for now)
Vegasaur could work in Movie Studio, but Sony Creative does not allow third-party developers (except VASST) to integrate their extensions in Movie Studio. So, it is a “political” restriction, not technical. -
Mike Kujbida
September 30, 2012 at 1:15 pmYou’re half-way there.
As I mentioned in a previous thread, look for a “Use count” column.
This will tell you if an event has been used more than once.
The problem is that it doesn’t tell you where this happens.
For that, switch over to the Edit Details tab (View – Edit Details).
Clicking on “Active Take Name” will change the sort so that you can find the file name you’re looking for.
Once you do this, it tells you exactly where on the timeline each event starts and ends.
It’s up to you to figure out which one is to be deleted. -
Jorma Nippala
September 30, 2012 at 3:48 pmNote that you’ll find the Edit Details option only in Vegas Pro.
Mike Kujbida
September 30, 2012 at 4:02 pm[Jorma Nippala] “Note that you’ll find the Edit Details option only in Vegas Pro.”
I did not know that.
That throws my suggestion out the window 🙁 -
Doyal Gudgel
October 1, 2012 at 3:11 pmThanks, You are right. That is the reason I could not find it. I have a dilemma Do I go buy the pro version when in 6 months I will be so blind I cant edit anyway? Do I want to spend that money for something of limited use? But at the same time I cant take it with me. If it weren’t for the setting up etc I would seriously consider it. To heck with it. It’s just a home movie anyway with not good source material to begin with. Leave it to Sony to know what to leave out. Thanks
