Activity Forums Apple Final Cut Pro Legacy finding clip in browser from subclip in timeline
  • finding clip in browser from subclip in timeline
    Posted by Aaron Metchik on April 14, 2008 at 11:23 pm
    By clicking on a clip in the timeline and hitting shift-F, you can find the clips master clip in the browser, but when you drag a marker from the browser to the timeline, and then highlight that (subclip) and hit Shift-F, FCP won’t find the marker or master clip in the browser for you. Is there a different way to do this?
    Aaron Metchik replied 18 years, 4 months ago 2 Members · 2 Replies
  • Carsten Orlt
    April 14, 2008 at 11:46 pm
    only way is to make a subclip from your marker(s)
    open the triangle of the clip with the marker in the browser – highlight the marker – select ‘make subclip’ from the Modify menu (I think).
    Now you have a subclip that behaves exactly like a master clip.
    The length of the subclip from the marker depends on:
    if you have a marker with a length – that will be the length of the subclip
    If not – either to the next marker or if no further marker to the end of the clip.
    Carsten
  • Aaron Metchik
    April 14, 2008 at 11:53 pm
    makes sense. thanks.
