Activity › Forums › Apple Final Cut Pro Legacy › Finding Audio Peaks?
Posted by Shiloh Heyman on September 7, 2007 at 7:14 amHi all,
I was wondering if there is a way to detect peaked audio in an eddited timeline, without having to play it in real time while watching the audio meters?
Thanks in advance.
Shiloh
Mac Pro 2.66, FCP6
Shiloh Heyman replied 19 years ago 3 Members · 5 Replies -
Michael Gissing
September 7, 2007 at 8:07 amIf you export an aif of the mixdown and import that into an audio system like Pyramix you can get a maximum peak readout on the file without playing it at all.
Within FCP I doubt this is possible but someone may have come up with a good trick for this.
Tom Wolsky
September 7, 2007 at 8:23 amIf you’re longing for overmodulated audio use Mark>Audio>Show Peaks. It’ll look through the active sequence and use extended markers over areas that reach zero. You can also normalize it to set audio to a specific peak level.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop” -
Shiloh Heyman
September 7, 2007 at 9:05 pmDear Tom.
I was under the impresseion that Mark>Audio>Show Peaks only worked within a clip and not a eddited sequence of clips. If it is possible to mark all the peaked audio in a sequence, can you please tell in detail all of the steps in this process? Everytime I try, the function is greyed out unless i use it on a single clip in the viewer.
Shiloh
Tom Wolsky
September 8, 2007 at 1:05 amMake the timeline the active window. Make sure nothing is selected and select it from the menu. It’s important to do it in the timeline because it combines track volumes.
All the best,
Tom
Shiloh Heyman
September 8, 2007 at 3:26 amThanks Tom,
I had to make sure that none of the clips in the timeline were selected for it to work.
Thanks again
Shiloh
