Activity Forums Adobe After Effects Expressions Finding an intersection of two lines and parenting it
  • Finding an intersection of two lines and parenting it
    Posted by John Burgess on June 3, 2020 at 11:11 am
    Hi, I am attempting to create a Lissajous curve table like the example driven by expressions.
    By rotating a point at different speeds around a circle and tracing the x and y position from each it will generate different curves.
    What I am struggling with is finding the the intersection of the x and y guides in red to then parent a shape layer to and use something like trails to draw them https://aescripts.com/trails/
    I have created the below by parenting the x and y guides to the radius of each circle that has a rotation applied and then offsetting it by the rotation speed so they don’t rotate.
    Doing this removes the ability to easily access the x or y position of the guides as they are being driven by rotation which makes me question if this is the best method?
    Thanks.
    thisComp.layer("radius").transform.rotation*-1
    thisComp.layer("radius").transform.rotation*-1.5-90
    John Burgess replied 6 years, 3 months ago 2 Members · 2 Replies
  • Robert Müller
    June 3, 2020 at 1:32 pm
    this should work just fine, you need to access the global position of your guides. I made a setup parenting a small white circle on an outlined one, driven by the rotation:
    xC=thisComp.layer("x1c"); //small white circle 1; For the X value
    yC=thisComp.layer("y1c"); //small white circle 2; For the Y value
    x=xC.toComp(xC.anchorPoint)[0]; //getting the global X value
    y=yC.toComp(yC.anchorPoint)[1]; //getting the global Y value
    [x,y]
    I added this expression to the position of a null which then I can trace using Write-on or the plugin you linked.
  • John Burgess
    June 3, 2020 at 3:53 pm
    Hi Robert
    This worked perfectly, thank you so much.
