Activity › Forums › Adobe After Effects › finding a specific frame
Posted by Lisa Simonson on June 23, 2010 at 2:28 pmI’m exporting an image sequence and my computer crashed. How do I find the last exported frame in the timeline to continue?
Todd Kopriva replied 16 years, 3 months ago 3 Members · 5 Replies -
Kevin Camp
June 23, 2010 at 2:40 pmcheck the folder where the sequence was being written. the last frame rendered should be the one with the highest number… ‘mymovie0099.tif’ for instance.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Kevin Camp
June 23, 2010 at 2:43 pmif your question was how to set the render to start from a specific frame, that is done in the render settings. the default is usually ‘work area’. change that to start on the frame after the last frame rendered.
i believe you’ll also need to set the end frame number too.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Todd Kopriva
June 23, 2010 at 3:22 pmYou could just redo the render with Skip Existing Files checked. After Effects will just pick up where it left off.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
