Activity Forums Apple Final Cut Pro Finder say FCPX libraries are larger than external hard drive, unable to backup
  • Finder say FCPX libraries are larger than external hard drive, unable to backup
    Posted by Michael Angelo on January 15, 2024 at 4:43 am
    Finder says FCPX libraries are larger than external hard drive, unable to backup drive! Maybe it has something to do with FCPX libraries being first created as far back as 2012? (documentary project still in progress)
    External Hard Drive = 12TB GRAID RAID 0, finder says drive has 21TB+ data
    Many thanks in advance for any guidance!
    Michael
    iMac Pro 2017
    MacOS: 11.7.9
    Processor: 2.3 Ghz 18-Core Intel Xeon W
    Memory: 128 GB 2666 MHz DDR4
    Graphics: Radeon Pro Vega 64X 16 GB
    Final Cut Pro X v10.6.5
    Michael Angelo replied 1 year, 12 months ago 4 Members · 4 Replies
  • Eric Santiago
    January 15, 2024 at 10:08 pm
    And your sure its not using the local?
  • Doug Metz
    January 16, 2024 at 4:46 pm
    I’d run Disk Utility on the external, see if there are errors. Given the age of the project (and your setup), I’m assuming the external is formatted HFS+ (Journaled) – if that’s the case, I’d also run DiskWarrior on it.
  • Patrick Donegan
    January 22, 2024 at 4:09 am
    Which of the many RAIDS out there do you have?
    And give a call to that manufactures tech support.
  • Michael Angelo
    July 26, 2024 at 9:11 pm
    Appreciate the feedback, this is related to symlinks, APFS vs HFS+ file systems, and HDD vs SSD hardware. Seems unavoidable unless all your drives are SSD APFS format. To understand and take a deeper dive into this challenge, check out this apple discussions thread:
    https://discussions.apple.com/thread/255413803?sortBy=best&answerId=260067272022
