sometimes it gets stuck on a bad file in the mediafiles folder.
you can peek in for obvious suspects (syntax stuff usually)and try to put them on the side and re-scan.
or use the method of halves, scanning a half of your media files each time until you find the problem
Hector Berrebi
prePost Consulting
