Activity › Forums › Adobe After Effects › find the handle
  • find the handle
    Posted by Roger Burton on July 14, 2005 at 5:32 pm
    This is really fundamental but I don’t need this too often but I’m manipulating an animation in some detail and I’m having a bit of trouble finding the bezier handles amongst all the other dots and stuff…I’m sure I read a trick to sort this but don’t recall where…hope you can help…best…Roger
    Roger Burton replied 21 years, 2 months ago 3 Members · 3 Replies
  • Kurt Murphy
    July 14, 2005 at 5:45 pm
    You can zoom into the point where the bezier is (> key) to make it easier to see, and holding down the command key while hovering over the keyframe will give you a tool to pull out the handle.
    kurt murphy
  • Avrohom Kohn
    July 14, 2005 at 7:19 pm
    Another idea,
    You can change the color of your mask lines by going in the timeline and to the left of where it says “mask” press on the yellow square. There you can change it to a color that will be most visible.
    good luck,
    -A.N.
  • Roger Burton
    July 15, 2005 at 5:13 am
    Thanks Kurt…that’s the one….and good tip AN…best…Roger
