Activity Forums Apple Final Cut Pro Legacy FIND in Description column
  • FIND in Description column
    Posted by Neil Ryan on August 3, 2005 at 3:39 am
    Is it just me?
    I can’t access the DESCRIPTION column in FCP’s Find function.
    Can see all others (well, a lot, anyway …)
    FCP 5.02
    Is it me … is it a bug?
    Tom Wolsky replied 21 years, 1 month ago 3 Members · 4 Replies
  • Uwe Klimmeck
    August 3, 2005 at 11:00 am
    It’s true.
    You can export as TAB delimited and rename to master comment 1 for example.
    Re-import, reconnect….
    I had more than 30.000 descriptions for my sound archive.
    No fun.
    Greetings
    Uwe
  • Tom Wolsky
    August 3, 2005 at 12:23 pm
    I can’t reproduce this. Could it be a language version thing? If I select a clip and go to logging info (I use Cmd-Shift-L),I tab once and Description is active and type in gaga. Then do a browser search for gaga Find All locates the one shot. Is this not happening for you?
  • Uwe Klimmeck
    August 3, 2005 at 12:32 pm
    Hi Tom,
    it will find the shot via “find all”.
    But because I have so many clips I wanted to narrow the search just to the “description” column.
    Just to speed up search. That doesn’t work.
    Greetings
    Uwe
  • Tom Wolsky
    August 3, 2005 at 1:03 pm
    I see what you mean. It’s missing from the column selection popup. I guess you sent in feedback on it. Probably just a silly oversight. I wonder if it was gone from earlier versions.
