Activity › Forums › Adobe Premiere Pro › Find Audio Peaks?
Find Audio Peaks?
Posted by Keith Moreau on February 4, 2011 at 4:30 pmIs there any way to have PPro quickly scan a sequence and locate any audio overload points? I can do this in FCP but can’t seem to find similar functionality in PPro. Thanks much for any advice.
Caine Mitchell replied 9 years, 4 months ago 4 Members · 3 Replies -
Vince Becquiot
February 4, 2011 at 7:03 pmYou can hit “K” 4 times to go to the fastest forward playback, that should pass through the timeline fairly quickly and identify any peaking.
In most cases, I use the dynamics filter with compression to each clip, so any peaking would be identified at this point.
For a quick and dirty way, you could normalize the master track.
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area -
Kevin Carlson
January 20, 2017 at 9:33 pmAnyone find any new ideas about this since it’s been several years?
I really miss being able to just have all the peaks marked like in FCP7!I wondered if a plugin has been created to do this?
Caine Mitchell
May 25, 2017 at 11:56 pmHi All
Has anyone found a solution to this???
FCP7 had this ridiculously efficient functionality from around 2002. Do we really need to rewatch an entire cut in this day and age, or trust PPro to flag an overloading peak when playing back in ffwd! But I guess as long as we can edit VR in PPro all is good right ;-(
All the best,
Caine
