Activity Forums Apple Final Cut Pro Legacy Find and Replace
  • Find and Replace
    Posted by Jack Phillips on May 21, 2007 at 7:46 pm
    Is there a way to “find and replace” information in the browser? I have a large number of clips that were captured from the same reel but given different names by different interns (i.e., Reel_01, Reel 01, and Reel01). Is it possible to do this is one fell swoop?
    Thanks.
    Jack
    Jack Phillips replied 19 years, 3 months ago 3 Members · 3 Replies
  • Arnie Schlissel
    May 21, 2007 at 10:44 pm
    FCP will not allow you to do this. The reel name is actually part of the QT file, and when you change it in FCP’s browser it will change it in the QT file as well.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Neil Ryan
    May 22, 2007 at 2:33 am
    You need to have at least one clip with the reel name you wish to use.
    Given that (manually change one clip first, if you don’t) multi-select all the clips you wish to correct, even if they have different reel names;
    right/control click the Reel Name of one of those clips;
    select the correct name from the list that appears;
    they’ll all be changed after you say YES to the pop up question.
    Its very quick ‘n’ easy.
    Hope that helps.
    Neil.
    Neil Ryan
    Post Production
    The Pod Multimedia
    http://www.the-pod.com.au
  • Jack Phillips
    May 22, 2007 at 11:03 am
    That’s it! Thank you very much.
