Activity Forums Adobe After Effects Expressions Find and Replace the item from bin to comp.
  • Find and Replace the item from bin to comp.
    Posted by Nathaniel Logan on February 26, 2020 at 5:57 pm
    Hello,
    I’m trying to replaceSource of a layer from the project bin/root to the Active Comp of particular Layer, also the position of the replaced layer has to match the position of the exisiting layer.
    I did happen to come up with a script that happened to be having lots of errors.
    Can you guys help me with this to figure out to achieve this, please…..
    Attaching a screenshot reference
    function getItem(theName){
    for (var i =1; i <= app.project.numItems; i++){
    if ((app.project.item(i)) && (app.project.item(i).name == theName)){
    return app.project.item(i);
    return null;
    function replaceFile(){
    var myComp = app.project.activeItem;
    var myItems = myItem;
    var myLayers = myComp.layer('blue.png');
    myItem.layer('blue.png').property("Position").setValue([positionValues[0],positionValues[1],positionValues[2]]);
    if (myLayers.length == myItems.length){
    for (var i = 0; i < myLayers.length; i++){
    myLayers[i].replaceSource(myItems[i],false);
    }else{
    alert("Number of selected layers and bin items does't match.");
    var itemName = "pink.png";
    var myItem = getItem(itemName);
    // alert(itemName + (myComp == null ? " not " : " ") + "found.");
    replaceFile();
    Nathaniel Logan replied 6 years, 6 months ago 2 Members · 6 Replies
  • Dan Ebberts
    February 27, 2020 at 12:00 am
    Try this:
    return null;
    if ((myComp == null) || ! (myComp instanceof CompItem)){
    alert("No comp active.");
    return;
    var myLayer = myComp.layer('blue.png');
    if (myItem == null){
    alert("Can't find item '" + itemName + "'.");
    return;
    myLayer.replaceSource(myItem,false);
    replaceFile();
    Dan
  • Nathaniel Logan
    February 27, 2020 at 12:08 am
    Hi Dan,
    Thank you so much, you’re the best ☺
    Exactly what I was looking for.
    Just one thing what if my comp is not active but I know my comp name how do I specify my comp name =|
    Thank you in advance.
  • Dan Ebberts
    February 27, 2020 at 12:16 am
    You could add a function to find a comp, like this (not tested):
    function findComp(theName){
    if ((app.project.item(i) instanceof CompItem) && (app.project.item(i).name == theName)){
    return null;
    If it returns null, the comp was not found.
    Dan
  • Nathaniel Logan
    February 27, 2020 at 12:29 am
    Hi Dan,
    Sorry to bother, I tried to edit the script to find the comp, but im getting an error.
    line 28. Function compName.layer is undefined.
    Please check the code that I modified.
    Pls help 🙁
    for (var i =1; i &lt;= app.project.numItems; i++){
    return null;
    return null;
    var setCompName = findComp(compName);
    var compName = "mycomp"
    var myLayer = compName.layer('pink.png');
    var itemName = "blue.png";
    return;
    replaceFile();
  • Dan Ebberts
    February 27, 2020 at 12:37 am
    try it like this:
    return null;
    return null;
    var compName = "mycomp";
    var myComp = findComp(compName);
    if (myComp == null){
    alert("Can't find comp '" + compName + "'.");
    return;
    var myLayer = myComp.layer('pink.png');
    return;
    replaceFile();
    Also, if you post code in this forum, please don’t preview your post. It messes things up.
    Dan
  • Nathaniel Logan
    February 27, 2020 at 1:03 am
    Hi Dan,
    Thank you so much, works like charm. ☺
    I see, the preview messed up the for loop. I will avoid that. 🙂
