Activity Forums Adobe After Effects Find and Replace colours in whole project
  • Find and Replace colours in whole project
    Posted by Harry Hoag on January 31, 2019 at 2:39 pm
    Hi
    Anyone know of a script that will let me find and replace all the colour fields in shape layers throughout a massive project?
    Classic client error, been given the wrong colour pallet at the start of the job, now at the end of the job I need to swap around 6 or so stroke and fill colours on a gazillion shape layers through a gazillion precomps. A script would be mighty hand right now.
    And ideas would be much appreciated ☺
    thanks
    H
    Jeremiah Bratene replied 6 years, 2 months ago 5 Members · 6 Replies
  • Oleg Pirogov
    February 2, 2019 at 9:28 am
    This script substitutes one color for another in all feasible properties (like effects, shapes’ fill colors etc) in all comps and layers:
    //converts a color channel from [0,1] range to hex string
    function channelToHex(channel){
    if (channel<0) return "00";
    if (channel>1) return "FF";
    var channelInt = Math.round(channel*255);
    var hex = channelInt.toString(16);
    if (hex.length == 1) hex = "0" + hex;
    return hex.toUpperCase();
    //recursive function to look for color properties; "path" variable is rudimental
    function colorSearch(thePropertyGroup, path, targetColor, substituteColor){
    for (var i=1; i<=thePropertyGroup.numProperties; i++){
    currentProperty = thePropertyGroup.property(i);
    //checking, if it's a property and not a property group
    if (currentProperty.propertyType == PropertyType.PROPERTY){
    //checking, if it's a color property
    if (currentProperty.propertyValueType == PropertyValueType.COLOR){
    //checking, if color value equals the targetColor (8 bpc) or is its 8 bpc equivalent (16, 32 bpc)
    if ([channelToHex(currentProperty.value[0]), channelToHex(currentProperty.value[1]), channelToHex(currentProperty.value[2])].join("") == targetColor){
    try{
    currentProperty.setValue(substituteColor);
    //mostly for handling hidden color layers
    catch(err){
    else{
    colorSearch(currentProperty, path+" -> "+currentProperty.name, targetColor, substituteColor);
    function main(){
    //dialog window
    var dialogWindow = new Window ("dialog", "Color Substitution");
    var targetColorGroup = dialogWindow.add("group");
    targetColorGroup.alignment = "right";
    targetColorGroup.add("statictext", undefined, "Target color:");
    var targetColorBoxGroup = targetColorGroup.add("group");
    targetColorBoxGroup.spacing = 0;
    targetColorBoxGroup.add("statictext", undefined, "#");
    var targetColorHex = targetColorBoxGroup.add("edittext", undefined, "FFFFFF");
    var substitutionColorGroup = dialogWindow.add("group");
    substitutionColorGroup.alignment = "right";
    substitutionColorGroup.add("statictext", undefined, "Substitute with:");
    var substitutionColorBoxGroup = substitutionColorGroup.add("group");
    substitutionColorBoxGroup.spacing = 0;
    substitutionColorBoxGroup.add("statictext", undefined, "#");
    var substitutionColorHex = substitutionColorBoxGroup.add("edittext", undefined, "0000FF");
    var buttonsGroup = dialogWindow.add("group");
    buttonsGroup.add("button", undefined, "Ok");
    buttonsGroup.add("button", undefined, "Cancel");
    var resp = dialogWindow.show();
    if (resp == 2){
    return;
    var prj = app.project;
    //converts hex string to [r, g, b, a] color; a = 1
    var hexToRGBa = function(hexColorText){
    hex = parseInt(hexColorText, 16);
    return [hex >> 16, hex >> 8 & 0xFF, hex & 0xFF, 255]/255;
    var targetColor = targetColorHex.text;
    var substituteColor = hexToRGBa(substitutionColorHex.text);
    //searching in every comp...
    for (i=1; i<=prj.numItems; i++){
    if (prj.item(i).typeName == "Composition"){
    currentComp = prj.item(i);
    //...and in every layer
    for (j=1; j<=currentComp.layers.length; j++){
    colorSearch(currentComp.layer(j), currentComp.layer(j).name, targetColor, substituteColor);
    main();
    Works fine as far as I’ve tested it.
  • Harry Hoag
    February 3, 2019 at 9:24 pm
    wow thanks man, I’ll give it a go!
  • Michael Szalapski
    February 7, 2019 at 10:25 pm
    In the future, you might check out Ray Dynamic Color. It’s a very handy tool that does this and a lot more.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Alex Restuccia
    April 23, 2019 at 2:36 pm
    Thanks, this is super helpful! But unfortunately it seems that it only works with layers using a Fill color, and it doesn’t change the Stroke color. Any idea how to change the script to support Stroke colors? Thanks!
  • Oleg Pirogov
    April 24, 2019 at 12:13 am
    As far as I’ve tested, it works for any unhidden color property: fills, strokes, effects, lights, – whatever.
    Could you please give more info on what exactly happens in your project?
    I suspect, it may just raise an exception on a half-way, simply not getting to the stroke color property.
  • Jeremiah Bratene
    June 26, 2020 at 12:29 am
    Just coming across this in 2020. I’m trying to replace the colors in several gradients, and this script would immensely speed up my process…however, I get this error when trying to use it:
    I’ve never scripted before, but I assume I’m supposed to replace that “undefined” with something…could somebody please help me figure out what to replace it with to get this script running?
  • Axel Kraut
    August 26, 2021 at 4:27 pm
    Hi Oleg, unfortunately the images don’t load for me (anymore). Can you me again how to get the script running? Would be a huge help!
