Activity Forums Adobe After Effects Expressions “Finalize” an expression to make editable
  • “Finalize” an expression to make editable
    Posted by Nicolas Hansen on August 4, 2008 at 4:25 am
    Hello, I have followed this light streak tutorial: https://library.creativecow.net/articles/kramer_andrew/nano.php
    What I would like to do is somehow “finalize” the position expression on the light that emits the particales and turn it into a bezier motion path so I can change certain parts.
    I like how the wiggle expression turns out, but some curves I would like to change, and the only way to do that is somehow make it a bezier curve somehow.
    I hope you get what I am trying to explain. Any help would be great! Thanks.
    Trent Armstrong replied 18 years, 1 month ago 2 Members · 1 Reply
  • Trent Armstrong
    August 5, 2008 at 3:50 pm
    I think what you would have to do hear is Convert Expression to Keyframes. The problem is that you’ll get a keyframe for every frame. Look under Animation Menu> Keyframe Assistants> Convert Expression to Keyframes.
    You might try to look at your Motion Graph and delete all but a few spread out keyframes. That would allow you to then use the bezier curves on those keyframes.
    It’s kind of tedious, but it works.
    Something you might try (this depends on your interest in Nulls) is to use the position of a Null to do fine adjustments on the position of the particle emitter.
    Good Luck!
    Trent
    Trent Armstrong – Creative Cow Leader
    https://www.dallasaeug.com
