Activity Forums Apple Final Cut Pro Legacy finalcutprohd does not identify 8Gb RAM
  • finalcutprohd does not identify 8Gb RAM
    Posted by Esra on April 27, 2005 at 1:22 pm
    Hi! Maybe i have a problem or not… Configurating FinalCutPro on the G5 the biggest amount of Ram the Program accepts is 2560MB for the Program and 2410MB for the Cache…actually i have 8GB RAM isnt it possible to use them all? Sometimes i have problems working in FCPHD and it tells me i dont have enough Ram…The Activity Monitor just can recognize 4 of 8 ram…they (apple) told me it is about the program(activity monitor) working with 32bit and my prozessor with 64bit so it divides my rams to the half?! I thought it could be a similar problem with FCP? or is it just normal and 2560MB is the maximum of ram i can use for the program? thanks for reading esra
    Esra replied 21 years, 4 months ago 3 Members · 3 Replies
  • Dan Brazil
    April 27, 2005 at 1:58 pm
    8Gig – not bad…That’s right, under the current system architecture of the G5 each individual application can only harness a maximum of 2Gb of RAM. But don’t fret it’s not wasted – it means you can run numerous applications at full whack simulataneously.
    Dan
    G5 DP 2.5; 4Gig Ram; Blackmagic Decklink Extreme; 23″ Cinema HD Display; Sony HR Trinitron PAL monitor with SD card; 500 Gig Lacie Big Disk Triple Interface; FCP HD; DVDSP3; After Effects 6.5; Photoshop CS; Illustrator CS; plus many others
  • Steve Eisen
    April 27, 2005 at 3:58 pm
    If it makes you feel any better, FCP 5 supports 4GB of RAM.
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.3.8 FCP 4.5, DVDSP 2, QT 6.5, Boris Red 3GL 1.65 TB External Stor
  • Esra
    April 27, 2005 at 4:35 pm
    ha cool good to know!
