Activity Forums Apple Final Cut Pro Legacy FinalCut Studio 2 – forgets serial
  • FinalCut Studio 2 – forgets serial
    Posted by Deva Sunya on September 13, 2007 at 10:07 pm
    Every time I launch one of the Final Cut Studio 2 applications, it asks for the name/org/serial # again.
    Have I done something wrong in the installation process? Is this a known problem? Any suggestions would be appreciated. Thanks
    Deva Sunya replied 18 years, 11 months ago 2 Members · 2 Replies
  • Michael Sacci
    September 13, 2007 at 11:02 pm
    there is a file HD/Library/Application Support/ProApps/Final Cut Studio System ID
    this maybe bad, delete it and hopefully it will only ask you one more time. If this is an upgrade you will need the old serial number also.
  • Deva Sunya
    September 13, 2007 at 11:50 pm
    That did the trick. Deleted the file, put the serial number in again, now the apps just launch as expected. Much appreciated. Never would have figured that out without some help! These forums are so useful!!
