Activity Forums Apple Final Cut Pro Legacy FinalCut Quicktime vs straight-up Quicktime
  • FinalCut Quicktime vs straight-up Quicktime
    Posted by Matthew Blum on December 17, 2008 at 8:45 pm
    What’s the difference between a “FinalCut Quicktime” vs “straight-up Quicktime”
    Some background info:
    I sent a .mov file to a post house to be put to HDcam-SR. The file I sent was a self contained quicktime using the AJA 4:4:4 codec at 1080p 23.98
    Any insight would be great.
    Andy Lancaster replied 17 years, 8 months ago 7 Members · 10 Replies
  • 10 Replies
  • Jerry Hofmann
    December 17, 2008 at 10:57 pm
    No technical difference, just that the FCP QT is set to open in FCP instead of QT… you can change that too by selecting the file, then choosing QT to open it.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Matthew Blum
    December 17, 2008 at 11:04 pm
    Okay, thank you, That’s what I thought.
    They’re saying it needs to be converted.
  • Ed Dooley
    December 17, 2008 at 11:13 pm
    No difference, except your post house needs the AJA 4:4:4 codec to open it, which they probably don’t, hence the “it needs to be converted”.
    Ed
  • Jeremy Garchow
    December 18, 2008 at 5:43 am
    The codec is available from AJA.com for free
  • Ed Dooley
    December 18, 2008 at 5:49 am
  • Matthew Blum
    December 18, 2008 at 6:30 am
    Thanks, but just to clarify, “FinalCut Quicktime” would a quicktime that needs a 3rd party codec to play and “straight-up Quicktime” is something mostly any Mac can play. Correct?
  • Curious Turtle
    December 18, 2008 at 7:13 am
    Nope.
    “Quicktime” is a type of container, just like an AVI or FLV. You can have many different types of codec that will fit into that container. A “Quicktime file” could be encoded with a number of different codecs, such as H264, DV or, in your case, the AJA 4:4:4 codec.
    Quicktime player comes bundled with lots of codecs, but if you try to play back a file that wasn’t encoded with one of those, then you will have to install that codec.
    To the extent that there actually exists a “Final Cut Quicktime” file is more down to the default handling of those files. After installing FCP one of the first things I do is to change it so that any QT file created in FCP will open automatically with QT Player instead. A personal preference obviously, and it has nothing to do with how compatible the files are.
    I hope I’ve made that clearer :o)
    Cheers,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Jeremy Garchow
    December 18, 2008 at 7:18 am
    What Ben says.
    You can’t play a DVD in a VHS machine, but the TV will show the signal it recevies from either machine.
  • Tom Wolsky
    December 18, 2008 at 9:34 am
    Not necessarily. A Final Cut Movie is basically a QuickTime file. It depends on the format you’re working in and the codec that’s used for export. Some codecs like DVCPRO HD and native HDV are only available to Final Cut Pro users. Some codecs like ProRes are not normally on people’s machines and might require the user to download a playback component.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Andy Lancaster
    December 18, 2008 at 4:54 pm
    How do you do this…
    ::After installing FCP one of the first things I do is to change it so that any QT file created in FCP will open automatically with QT Player instead. A personal preference obviously, and it has nothing to do with how compatible the files are::
