Activity Forums Apple Final Cut Pro Legacy Finalcut OMF’s to Nuendo, does it work ??? Deadline closing in
  • Finalcut OMF’s to Nuendo, does it work ??? Deadline closing in
    Posted by Anders Haavie on October 14, 2005 at 9:03 am
    We usually use Protools guys for sound postpodruction, bu now I have ended up with some Nuendo guys doing sound for us.
    Apperantly my omf’s dont give them rubberbands info, neither does nuendo import xml information (or so I have been told) How do I give them my rubberband info
    Can this be fixed ?? I am on a tight deadline.
    Anders
    Samuel Frazier replied 20 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    October 14, 2005 at 9:19 am
    Automatic Duck. Look it up and see if it will do this for Nuendo. I know it does it for ProTools.
    And as far as I knew, I thought that the OMF directly from FCP to protools ALSO didn’t preserve the rubberbanding. That you needed the Duck for that too…
  • Anders Haavie
    October 14, 2005 at 9:46 am
    Well. My protools guys told me that with fcp 5.0 the rubberband info is preserved within the omf file !!!
    Great..
    Anders
  • Shane Ross
    October 14, 2005 at 9:51 am
    That’s nice to know.
    Not that my protools guy uses my prelay. Sometimes he does, sometimes he does it from scratch. But nice to know that it is now preserved.
  • Wes Plate
    October 14, 2005 at 7:50 pm
    No, this is not the case, even in the latest FCP there is no volume info in the built-in OMF export.
    Our Pro Export FCP plug-in does preserve volume information, and Nuendo 3.1 will be able to read it.
    Just be sure that before you do the export you read the user guide, you’ll need to disable the export of pan information so that Nuendo will read the “rubberbands”.
    — Wes Plate
    Automatic Duck
  • Samuel Frazier
    October 14, 2005 at 9:34 pm
    Also, Automatic Duck only transfers keyframed volume changes into Nuendo. That means if you use the pen tool anywhere on the volume of the clip then it carries over. But, if you just raised or lowered the volume without a keyframe then it won’t carry over. Hope I’m explaining this okay. Anyway, check their manual as it explains it much better than I just did.
  • Wes Plate
    October 14, 2005 at 9:44 pm
    More accurately, we put volume information into the OMF, even clip-based gain. However Nuendo 3.1 is only able to read keyframed volume information from our OMFs.
    — Wes Plate
    Automatic Duck
  • Samuel Frazier
    October 15, 2005 at 2:57 am
    Right, I’m sorry, Wes. The fault definitely lies with Nuendo. That said, I REALY REALY hope Automatic Duck figures out a way to add keyframes to the front and tail of all audio clips to work around Nuendo’s deficiency.
