Activity Forums Sony Cameras Finalcut MOV into Vegas
  • Finalcut MOV into Vegas
    Posted by Matthew Beall on January 14, 2010 at 6:36 pm
    I have two Finalcut XDCam EX Quicktime MOVs that I would like to use in Sony Vegas.. Will Vegas import the files correctly, or do I need to get a codec or something?
    -Matthew
    Craig Seeman replied 16 years, 4 months ago 3 Members · 4 Replies
  • Craig Seeman
    January 14, 2010 at 6:46 pm
    CalibratedSoftware has a EX MOV decoder for Windows.
    https://www.calibratedsoftware.com/QXD.asp
    The app must support Quicktime though (that’s what MOV is after all).
    Read the page carefully and download the trial version.
    If this doesn’t work then you’d need to get the original BPAV (contains original MP4 files).
    If the video was edited in Final Cut Pro, FCP can export EX MP4 and ClipBrowser can create a BPAV for it.
  • Matthew Beall
    January 14, 2010 at 6:52 pm
  • Julian Gil
    January 18, 2010 at 5:05 pm
    Another option is to export the sequence or clips as ProRes. Win QT now reads ProRes and therefore so does Vegas.
  • Craig Seeman
    January 18, 2010 at 8:16 pm
    Yes, that might work and if you don’t have ProRes decoder on your Windows box, Apple makes the decoder freely available. Keep in mind that the NLE has to be aware of Quicktime Components though so I’d certainly test before committing to a massive encode (and at much larger file sizes).
