Activity Forums Apple Final Cut Pro Legacy FinalCut… Everything in the timeline has to render….! Help
  • FinalCut… Everything in the timeline has to render….! Help
    Posted by Doug Normington on February 20, 2006 at 10:13 pm
    I have a decklink card. I am digitizing from my beta deck. I am set up with audio and video settings of Blackmagic jpg.
    Everytime I digitize a clip and put it in the timeline it has to render….
    What is the @!#%$^ secret to this madness? I just want it to play. I don’t want to render every little thing.
    NORMCO
    John Kennedy replied 16 years, 7 months ago 5 Members · 5 Replies
  • Debe
    February 20, 2006 at 10:21 pm
    Your sequence settings need to match the settings for the clips you captured.
    Double check those, and if that doesn’t solve the problem, post back!
    debe
  • Walter Biscardi
    February 20, 2006 at 10:26 pm
    [debe]
    Your sequence settings need to match the settings for the clips you captured.”
    Ditto. Use an Easy Setup to ensure that everything matches.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Doug Normington
  • Tony
    February 20, 2006 at 11:02 pm
    You might also want to check if RT extreme is enables when using the particular codec you have chosen.
    Tony Salgado
  • John Kennedy
    January 11, 2010 at 4:47 am
    I’m using FCP 6.0.6 right now, is there any way i can automatically set the SEQ to the setting of my media?
    I’m using both QTs shot on a Canon Dslr (awesome looking 1080i video) and some 1080HDV footage. I want to sent my sequence to the QT because they are the bulk of my source media but i can’t seem to get the correct settings in which the red un-rendered bar disappears.
    John Kennedy
