Activity Forums Adobe After Effects Final render without continuous rasterizing of Illustrator images.
  • Final render without continuous rasterizing of Illustrator images.
    Posted by David Percevault on November 27, 2016 at 8:46 pm
    Hello…
    Is the continuous rasterizing of Illustrator files in AE only for preview purposes? or will this setting also affect the final output render of the composition? The thought came to mind because I was thinking how (and if) final render times are affected by this setting…. or maybe AE just does its thing regardless when it comes to final output.
    Roei Tzoref replied 9 years, 9 months ago 2 Members · 1 Reply
  • Roei Tzoref
    November 28, 2016 at 12:40 am
    [David Percevault] “Is the continuous rasterizing of Illustrator files in AE only for preview purposes?”
    the only time you need to continuously rasterize an illustrator layer is when you want to scale it above 100% and not lose quality. (another case is for render order purposes but this is rarely the case). so if you don’t need to, leave it unchecked and save render time. if you need it to be on, it’s calculations are obviously taken into account when you render because Ae has to rasterize everything before it renders the frame.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
