Activity › Forums › Apple Final Cut Pro Legacy › Final Render Video Processing – 10-bit Uncompressed
  • Final Render Video Processing – 10-bit Uncompressed
    Posted by Jay Moffat on January 25, 2010 at 11:26 am
    Hi, I have done a final render of a 10-bit uncompressed sequence, graded footage from Apple Color, added titles, Subtitles, transisitons etc, and set the Video Processing for the final render as ‘Render 10-bit Material in High-precision YUV’.
    I just wanted to check this is correct? Is 10-bit Uncompressed a YUV codec or is it RGB? Should I be rendering out to RGB instead?
    Jason
    Jay Moffat replied 16 years, 8 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    January 25, 2010 at 1:19 pm
    If the source material was SD video, then don’t render in RGB.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Rafael Amador
    January 25, 2010 at 2:07 pm
    Yes.
    If the Sequence is 10b and all the footage is 10b too, you don’t have to care about these setting.
    This is to force 10b rendering in an 8b sequence, or 8b footage in a 10b sequence.
    rafael
    http://www.nagavideo.com
  • Jay Moffat
    January 25, 2010 at 3:04 pm
    Great thanks, it’s an HD sequence, 10-bit, there is an 8-bit title sequence, so looks like I’ve done the correct thing then..
    J
