Activity Forums Adobe After Effects Final render result distorted
  • Final render result distorted
    Posted by Phil Brough on February 1, 2010 at 10:13 pm
    Hi there I am rendering a 50 frame sequence 1920 HD. When I ram preview this is looks clean and fine but when I render it and watch it back the images come out distorted like they have a weird ripple effect going through them. Anyone have any ideas why this might be happening?
    Phil Brough replied 16 years, 7 months ago 2 Members · 3 Replies
  • Steven Savalle
    February 1, 2010 at 10:46 pm
    What compression are you rendering them in?
  • Phil Brough
    February 1, 2010 at 11:07 pm
    haha, whoops. Right here goes. I am using a PC Intel Core 2 Quad Q9540 2.66 GHZ.
    I have 4 Gb of ram and am running Windows Vista Ultimate 64bit.
    Graphics card is Nvidia Geforce 8800 GT.
    I am working from a bunch of iff image sequences rendered out of Maya. I am rendering out animation codec QT movies but also tried an image sequence and the same distortion effect occurred. I have enabled disc cache with a maximum disc cache size of 2000 mb. I am unsure about open GL although I do have that switched off in the preview settings in After effects.
  • Phil Brough
    February 2, 2010 at 2:53 am
    How embarrassing, I found the problem. I had turned on frame blending and motion blur on some layers but then turned it on in the comp. So it was previewing without it but rendering with it.
