Activity Forums VEGAS Pro FINAL question! Blurry/interlaced rendering.
  • FINAL question! Blurry/interlaced rendering.
    Posted by Paul Johnson on December 31, 2007 at 5:15 pm
    Please see attached image!
    https://img525.imageshack.us/img525/7457/vegasproblemsdt4.jpg
    Okay, thanks to all the help I’ve now got a cityscape zooming toward the viewer.
    Unfortunately, no matter what options, settings, rendering quality or actual event preferences (reduce interlace flicker, etc) I choose for rendering, the result is exactly the same. Blurry, and with choppy lines through everything.
    Do you have any ideas for fixing this? Because the final video is pretty much an unwatchable, flickery mess at the moment.
    Paul Johnson replied 18 years, 8 months ago 2 Members · 2 Replies
  • Edward Troxel
    December 31, 2007 at 9:23 pm
    Are you seeing this on a TV or computer screen? Interlaced footage is required for a TV. However, computers are progressive. You might try rendering progressive and seeing if that makes a difference.
    Edward Troxel
    JETDV Scripts
  • Paul Johnson
    January 2, 2008 at 12:09 am
    Hello again.
    Well, I messed around with some options and it turns out that switching to “lower field first” on all layers and renders sorted things out quite nicely! So all is well.
    Thanks again!
