Activity › Forums › Adobe Premiere Pro › Final output format
Final output format
Posted by Gina Sarentino on April 14, 2014 at 4:52 pmHy everyone, in a couple of months ill be outputting a feature film for cinema and for dvd and film festivals. Im editing ,y film on premiere and color correcting in Davinci Resolve, the final output will be from Premiere. I wanted to know what would be the ideal format for cinema??
Gina Sarentino replied 12 years, 4 months ago 2 Members · 5 Replies -
Angelo Lorenzo
April 14, 2014 at 6:25 pmOutput DNxHD 220x or ProRes HQ 422 as your “master” formats. Generally each film festival will have delivery specs. If they require a DCP, I suggest paying the lab fee for them to make one, in which case you can deliver them either of the above to prep one for you.
DVD is, of course, DVD so it’s MPEG-2 and Premiere has output settings optimized for that.
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter -
Gina Sarentino
April 14, 2014 at 6:32 pmOkay regarding proress how would i output proress on a windows pc. And what about h.264would ou recommened that?
Angelo Lorenzo
April 14, 2014 at 6:49 pmIf you aren’t able to do ProRes then DNxHD (either MXF or MOV wrapped) should be fine https://avid.force.com/pkb/articles/en_US/download/Avid-Codecs-LE-2-3-9
As far as h.264, I would do whatever you consider suitable quality for YouTube or Vimeo. This will probably act as your submission screener. Again, I hesitate to spit out a dozen different formats without knowing submission specs – things can be all over the place, especially preferred sound mix and channel assignment (I hope you have at least a left-center-right mix for festivals).
Gina Sarentino
April 14, 2014 at 6:59 pmThanks for the reply Angelo, the sound is sorted out I just wanted to do some additional research on the output for the film and get some insight.
Thanks again im going to start looking into DNxHD.
Gina Sarentino
April 14, 2014 at 8:08 pmI just have one more question, im going to be outputting this film for 2k cinema is DNxHD still fin for it?
